mjhpadi Posted December 28, 2011 Report Share Posted December 28, 2011 So I see that several people are using Unleashed Tuning 170 degree thermostat. Which brings up several questions: First, what is the benefit to the Ecoboost engine by using this thermostat? Second, what is the temp of the stock thermostat? Lastly, is there any down side to replacing the stock thermostat with the 170 thermostat? Thanks in advance for everyone's input. Link to comment Share on other sites More sharing options...
darreli Posted December 28, 2011 Report Share Posted December 28, 2011 I'm running the Unleashed t-stat as well as the radiator. In my opinion the cars seem to run very hot, very quick and was hoping this would help out. The stock t-stat is 180. With my current setup I've seen the temps drop about 15 degrees on average. During a 1/4 mile pass I used to see temps around 210, now they really never go above 195 Link to comment Share on other sites More sharing options...
EcoBrick Bob Posted December 29, 2011 Report Share Posted December 29, 2011 It also lowers your operating temp by several degrees. The big benefit I have seen at the track is that my vehicle cools down to normal operating temp by the time I get my time slip. Do think the Flex has fewer cooling issues overall, since it is designed to tow up to 4,500 lbs. Link to comment Share on other sites More sharing options...
tmcphail Posted December 29, 2011 Report Share Posted December 29, 2011 The more you modify the factory cooling system the better, it works well within its original design specification. But once you migrate outside of that scope it needs assistance. Plus I can alter the fan temperature schedule (though calibration) to take advantage of the 170 as well. Link to comment Share on other sites More sharing options...
The Bone Posted December 30, 2011 Report Share Posted December 30, 2011 Thisa has been discussed at leignth on the GT500 sites and from what I have deduced is if you just track you're car then just upgrading the T stat is fine but for a street car not a good idea it messes with the computer and shows that the car doesn't come up to running temp.If you want to change it go ahead but I see no real advantage to it.I am still running the stock T stat in my GT500 and I'm pushing 550 at the tires. No problem with overheating. I do however need to upgrade the intercooler to a bigger one Link to comment Share on other sites More sharing options...
chad1140 Posted February 7, 2012 Report Share Posted February 7, 2012 A GT500 isn't an ecoboost though. Link to comment Share on other sites More sharing options...
tmcphail Posted February 7, 2012 Report Share Posted February 7, 2012 A GT500 isn't an ecoboost though. Bingo...... Link to comment Share on other sites More sharing options...
bpd1151 Posted February 7, 2012 Report Share Posted February 7, 2012 I too am running Torrie's 170 lower temp t-stat :wave: Thanks Torrie! :thumb: Sent from my DROID3 using Tapatalk Link to comment Share on other sites More sharing options...
tmcphail Posted February 7, 2012 Report Share Posted February 7, 2012 I too am running Torrie's 170 lower temp t-stat :wave: Thanks Torrie! :thumb: Sent from my DROID3 using Tapatalk Sure thing ! Link to comment Share on other sites More sharing options...
