griggs95 Posted November 19, 2012 Report Share Posted November 19, 2012 My SHO is pretty much stock except for a Livernois stage 2 tune (91 octane). Car has been amazing until I just got my Magnaflow mufflers installed. The gas mileage seemed to drop a little and the car doesn't seem as fast. :RpS_sad: My question is, do I need to retune it since I freed up the exhaust a bit? Is the car designed to run with the amount of back pressure from the factory crap mufflers? I thought you guys might know before I bother Rick with an email for a retune, thanks a lot for any info. Link to comment Share on other sites More sharing options...
mjhpadi Posted November 19, 2012 Report Share Posted November 19, 2012 I don't believe you will need a retune, several others have changed their exhaust without changing their tunes. Link to comment Share on other sites More sharing options...
bpd1151 Posted November 19, 2012 Report Share Posted November 19, 2012 Have you checked at all for those infamous, dasterdly chaffed wires syndrome? The conditions you are describing are spot on for such similar experiences by several members / owners here. I'd check for that 1st. Link to comment Share on other sites More sharing options...
Leadfoot Posted November 19, 2012 Report Share Posted November 19, 2012 If it's not the chaffed wires and the loss of power happened right when you changed the exhaust, maybe you have a defective muffler or other restriction. Is exhaust coming out of both pipes? Can you put the original exhaust back to see if it improves? Link to comment Share on other sites More sharing options...
Paulford8 Posted November 19, 2012 Report Share Posted November 19, 2012 Mine sped up after Magnaflows. I did find the knock sensor wires rubbing, but not rubbed through yet. I just zipped tied mine up. The issue is the rub through and cause a false knock sensor signal... May not be your problem but worth checking as bpd mentioned. Link to comment Share on other sites More sharing options...
griggs95 Posted November 20, 2012 Author Report Share Posted November 20, 2012 I had a pretty good run up the mountain tonight and the car felt really strong. I haven't checked the knock sensors yet but the car has 28k on it so it's possible they are rubbing. Will look into the next couple days when i get a moment to work on her a little, thanks a lot for the advice. Definitely not a bad muffler though as there both flowing just fine. Link to comment Share on other sites More sharing options...
MTaurusSHO Posted November 22, 2012 Report Share Posted November 22, 2012 Was this problem fixed from ford on a certain year? I I have a 2013, should I check my wiring? Where are the sensors located? Link to comment Share on other sites More sharing options...
mjhpadi Posted November 22, 2012 Report Share Posted November 22, 2012 I don't believe that it was ever corrected, Ford does not know this problem exists (as far as we are aware). My dealer had never heard of this problem until I showed the service manager, since it was discovered by one of the guys here. I think that the wires may have been moved on the 13's but I can't say that for sure. Link to comment Share on other sites More sharing options...
SHO Rod Posted November 22, 2012 Report Share Posted November 22, 2012 My SHO is pretty much stock except for a Livernois stage 2 tune (91 octane).Car has been amazing until I just got my Magnaflow mufflers installed. The gas mileage seemed to drop a little and the car doesn't seem as fast. :RpS_sad: You may want to clear the Keep Alive Memory (KAM) to see if that helps out. The KAM is the memory that tailors parameters based on your driving style. I've found that over time they seem to cause a decrease in performance and once I clear the KAM, the car seems to wake up again. It's unclear if you can clear the KAM by clearing the codes on our SHO's, but if you put the car back to stock and then retune it will certainly clear the KAM. -Rod Link to comment Share on other sites More sharing options...
EvansEcoSHO Posted November 24, 2012 Report Share Posted November 24, 2012 Thanks for that info SHO Rod. I never thought about that but I usually return my car to stock every other week when my wife uses my SHO to commute to work to save miles on her car which is a lease. Stage 2 is great to drive around on for me so when a guy in a challenger or camaro pulls up next to me at the light, i can rev at them, watch them laugh, then smoke the crap out of them to the next light. In fact, My buddy mike just cammed and tuned his RT challenger. He also has strait pipes and headers with a bigger TB and i still smoked him by a car and a half tonight only on stage 2! Link to comment Share on other sites More sharing options...
mjhpadi Posted November 25, 2012 Report Share Posted November 25, 2012 Thanks for that info SHO Rod. I never thought about that but I usually return my car to stock every other week when my wife uses my SHO Not sure why you would return it to stock when your wife drives it....I know I get better gas mileage with the tune my wife is going to drive her normal way, regardless of how the car is tuned. I would suggest leaving the tune in the car, you might be pleasantly surprised by seeing a slight improvement in mpg. Link to comment Share on other sites More sharing options...
griggs95 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Thanks for the extra tip shorod, I had no idea about the KAM. The wires aren't chaffed like I was thinking, so maybe I'll just reset the car to factory then back to stage 2. The car has been running fine for several days now so not really sure at this time ,bad fuel was a possible cause too..... Link to comment Share on other sites More sharing options...
EvansEcoSHO Posted November 29, 2012 Report Share Posted November 29, 2012 The problem is that the tune makes my car shift really hard. My wife hates when it kicks hard and ive already had to have the tranny rebuilt once before. Link to comment Share on other sites More sharing options...
Toxie Posted November 29, 2012 Report Share Posted November 29, 2012 Just as an aside, but generally speaking the "harder" (and faster) a trans shifts the less wear it generally takes because it's less time the clutch packs have to slip. That's as long as the rest of the hardware isnt under spec for provided torque of course. Counter-intuitive I know, but still . Link to comment Share on other sites More sharing options...
mjhpadi Posted November 29, 2012 Report Share Posted November 29, 2012 Boy, I can't remember if I ran Stage 2 or 3 before going to 4+ but I know that the car never shifted that hard and doesn't with the current tune. Maybe if you are still having the hard shift you could try running Stage 3 and see if that is more to your wife's liking. But I think shifting back and forth makes it really difficult for the car to "learn" driving habits. Link to comment Share on other sites More sharing options...
Crash712us Posted November 29, 2012 Report Share Posted November 29, 2012 Stage 2 I felt shifted hardest out of all the tunes. The 4+ tune shifts a lot smoother as LMS put torque management back in. Link to comment Share on other sites More sharing options...
tss Posted November 30, 2012 Report Share Posted November 30, 2012 Yeah, no hard shifts for me either (4+). Link to comment Share on other sites More sharing options...
EvansEcoSHO Posted November 30, 2012 Report Share Posted November 30, 2012 I cant drive stage 4+ out here we dont have 93 octane out here. The best we have is 91 unless i want to spend $9 a gallon on 100 lol. Ill try stage 3 tomorrow on my drive to vegas. Link to comment Share on other sites More sharing options...
Crash712us Posted November 30, 2012 Report Share Posted November 30, 2012 If I remember correctly stage 3 shifts smoother. Also you want contact Rick to see if they can put in torque management in on your stage 2 file. Link to comment Share on other sites More sharing options...
