SHO-MAN Posted January 7, 2012 Report Share Posted January 7, 2012 Just pulled the SHO out of the garage this morning....notice staining on the floor :RpS_huh: as I checked it out, it looks like carbon from the muffler. With the car running, I noticed water dripping from muffler (not tailpipe). Now the only modifications to the car recently was the installation of the gauges/pod. I use 93/94 fuel. Is it possible that the gauges could be the culprit? The gauges that I installed are water temp, oil pressure and boost. Any one have any suggestions? Link to comment Share on other sites More sharing options...
Scrming Posted January 7, 2012 Report Share Posted January 7, 2012 Totally normal.... there are actually little drain holes on the back side of the mufflers... you can sort of see it here: Link to comment Share on other sites More sharing options...
SHO-MAN Posted January 7, 2012 Author Report Share Posted January 7, 2012 Leaking from center of car..... Catalyst? Link to comment Share on other sites More sharing options...
mjhpadi Posted January 7, 2012 Report Share Posted January 7, 2012 I agree sounds normal to me, and after seeing all the stuff in the muffler, it isn't surprising that water collects in these mufflers...besides it occurs in almost all vehicles, I've owned a few that had water drip from the tips of the exhaust. One of the things that helps prevent that is running the vehicle on longer trips so that the exhaust can get hot enough to evaporate all the water in the system. Link to comment Share on other sites More sharing options...
SHO Rod Posted January 7, 2012 Report Share Posted January 7, 2012 Yep, it's normal. It's probably a mix between condensation and moisture that's a product of the catalytic converters doing their job, converting unburned fuel to water. If it's continually occurring, even after a long drive, or the converters are getting hot, then you probably have a rich fuel mixture and would need to get that checked out. -Rod Link to comment Share on other sites More sharing options...
SHO-MAN Posted January 7, 2012 Author Report Share Posted January 7, 2012 Thanks guys Link to comment Share on other sites More sharing options...
