mjhpadi Posted June 20, 2014 Report Share Posted June 20, 2014 After changing out the spark plugs, I took a few photos to show the difference of the two. These plugs have 27K total miles on them. about 4K with the Stage 2 tune and 19K with old SCT Stage 4+ tune...remainder of the miles were run stock. Sorry the new plugs aren't in better focus...didn't realize it until I downloaded the photos: Quote Link to comment Share on other sites More sharing options...
tss Posted June 21, 2014 Report Share Posted June 21, 2014 Holy crap. I am replacing mine tomorrow. mjhpadi 1 Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted June 21, 2014 Report Share Posted June 21, 2014 I've seen a lot worse but I think I will be changing mine every 20K now. Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted June 21, 2014 Author Report Share Posted June 21, 2014 Don't forget the anti-seize on the threads and di-electric on the boot and porcelein of the plug. And be gentle getting the coil pack and boot off. tss 1 Quote Link to comment Share on other sites More sharing options...
ShoBoat Posted June 21, 2014 Report Share Posted June 21, 2014 I would also recommend, if they are original to have a few of the boots on hand. They are a pita to get the coil packs off the first time. I separated one on my first change. It got stuck on the plug. I had to use a pair of needle nose pliers to get it off the plug. And the boot was damaged getting it off. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted June 21, 2014 Author Report Share Posted June 21, 2014 Great idea, I didn't realize the boots came off the COP! Also instead of using needle nose pliers, won't it be better to get one of those specialized pair that is made to grip the spark plug boot? Quote Link to comment Share on other sites More sharing options...
tss Posted June 21, 2014 Report Share Posted June 21, 2014 Thanks for all the tips. Quote Link to comment Share on other sites More sharing options...
SHO Rod Posted June 22, 2014 Report Share Posted June 22, 2014 Also instead of using needle nose pliers' date=' won't it be better to get one of those specialized pair that is made to grip the spark plug boot?[/quote'] I haven't seen any plug boot pliers that will work with the deep plug wells that these COP setups use. If someone does know of a plug boot pliers for this type of application, please share source and part number. -Rod mjhpadi 1 Quote Link to comment Share on other sites More sharing options...
bamsho Posted June 25, 2014 Report Share Posted June 25, 2014 Actually Mark's coils came off fairly easy as compared to mine. I wiggled them and twisted and they came right off, but be gentle. Did the same thing to my car too. Yeah, I found out about the boots on my Gen3. It actually was a good thing, cause I used the old ones to see how much of the coil wire to trim off. I modded 4.6/5.4 DOHC Accel coils to work in the 3.4. mjhpadi 1 Quote Link to comment Share on other sites More sharing options...
bamsho Posted June 25, 2014 Report Share Posted June 25, 2014 Mark's #5 cylinder was the only one really out of spec, the other where just at .030 or .032, not the original .035. mjhpadi 1 Quote Link to comment Share on other sites More sharing options...
shoman04 Posted June 26, 2014 Report Share Posted June 26, 2014 Don't forget the anti-seize on the threads and di-electric on the boot and porcelein of the plug. And be gentle getting the coil pack and boot off.mjhpadi what MOD's do you have on you car? Do you have METH ? Are the new plugs the SP534 or SP523 and what gap? Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted June 26, 2014 Author Report Share Posted June 26, 2014 I have the new Stage 4+X tune 3 bar sensor 160 thermostat, and Airaid CAI. Do not have meth. Plugs are SP 534 gapped at .030. Sent from my DROID RAZR using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Guest Posted June 26, 2014 Report Share Posted June 26, 2014 Love your new list of mods Mark! Quote Link to comment Share on other sites More sharing options...
shoman04 Posted June 26, 2014 Report Share Posted June 26, 2014 I have the new Stage 4+X tune 3 bar sensor 160 thermostat' date=' and Airaid CAI. Do not have meth. Plugs are SP 534 gapped at .030. Sent from my DROID RAZR using Tapatalk [/quote']Thanks You. I will be changing my plug because when I went to track 2weeks ago(at the track) the car stuttering at 5500-6000rpm in 3rd and 4th gear every body think I have a bad plug problem. Quote Link to comment Share on other sites More sharing options...
