bamsho Posted March 19, 2015 Report Share Posted March 19, 2015 Hey need a favor guys, Any of you running the LME 160tstat and Aeroforce gauge, could you see what temps you are running at. I came home this morning, outside temp was 26 degrees and coolant was running in the 180's with the lowest begin 177. Seems way high for running a 160tstat. Thought I would ask before I pulled it out and check it out in hot water. Thanks EkbergJen and RudyFloum 2 Quote Link to comment Share on other sites More sharing options...
bamsho Posted March 19, 2015 Author Report Share Posted March 19, 2015 Just found out that those temps are normal. Makes me feel much better. Thanks. DJE 1 Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted March 19, 2015 Report Share Posted March 19, 2015 I was kinda surprised when I found out that a 160 thermostat doesn't make the engine run at 160....so I am really glad that I took LME's suggestion of replacing the stock thermostat with the 160. I was also impressed with the quality of the new thermostat from Livernois! Quote Link to comment Share on other sites More sharing options...
Livernois Motorsports Posted March 23, 2015 Report Share Posted March 23, 2015 I was kinda surprised when I found out that a 160 thermostat doesn't make the engine run at 160....so I am really glad that I took LME's suggestion of replacing the stock thermostat with the 160. I was also impressed with the quality of the new thermostat from Livernois! Firstly, thank you for the compliments! The thermostat will not keep everything that 160°. We are opening the tstat at 160° as opposed to the factory ~178°. So cooling starts earlier. Ford does power testing at ~140°, so all that we are doing is getting you as close we can while keeping the creature comforts of a modern vehicle. DJE 1 Quote Link to comment Share on other sites More sharing options...
tss Posted March 23, 2015 Report Share Posted March 23, 2015 I generally run in the mid 180s to low 190s with the LME 160 Stat. Also, I have been told (by others with no skin in the game - my dealer - NOT LME), that the LME 160 stat is a very high quality T-Stat. I don't notice any longer heater warm up times either. Quote Link to comment Share on other sites More sharing options...
tss Posted March 28, 2015 Report Share Posted March 28, 2015 What do you guys run on the highway at like 75 to 80? Still trying to figure out if I am running right on temps. Quote Link to comment Share on other sites More sharing options...
DJE Posted March 28, 2015 Report Share Posted March 28, 2015 I think I was running about 185-188. Quote Link to comment Share on other sites More sharing options...
tss Posted March 28, 2015 Report Share Posted March 28, 2015 Thanks Dave /\. Quote Link to comment Share on other sites More sharing options...
bamsho Posted March 28, 2015 Author Report Share Posted March 28, 2015 Yeah, been keeping an eye on temp the couple times I've had here out. Staying in the 180's. Quote Link to comment Share on other sites More sharing options...
brucelinc Posted March 28, 2015 Report Share Posted March 28, 2015 So, is it accurate to say that when fully open, the 160 and 180 t'stats both run about the same temperatures when cruising down the highway? tss 1 Quote Link to comment Share on other sites More sharing options...
DJE Posted March 28, 2015 Report Share Posted March 28, 2015 180's is good. brucelinc 1 Quote Link to comment Share on other sites More sharing options...
mjhpadi Posted March 28, 2015 Report Share Posted March 28, 2015 I really do have to find someone to help me install my gauges and pod...I still can't believe that no mechanic here wants to tackle installing the gauges..... Quote Link to comment Share on other sites More sharing options...
