83racecrew Posted February 6, 2013 Report Share Posted February 6, 2013 Joining may not have been a good idea :madgrin: :tongue: Quote Link to comment Share on other sites More sharing options...
bpd1151 Posted February 6, 2013 Report Share Posted February 6, 2013 Everyone will tell you here..... That mod is just the beginning of the insanity. Sent from my DROID3 using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 7, 2013 Author Report Share Posted February 7, 2013 I need to not get too carried away, for now the car is leased and I don't think they take kindly to missing badges, etc. Plasti Dip seems like a good way to change the appearance while I have it, I can always remove it if I decide not to keep the car. Quote Link to comment Share on other sites More sharing options...
Echo42987 Posted February 7, 2013 Report Share Posted February 7, 2013 I have a tendency to stay away from the Plasti-dip. I've had nothing that has lasted. I used the Krylon Plastic Spray paint in matte black and a couple coats of clear to lock it in. Hasn't even started to wear on me yet through the winter. The plasti-dip, I was able to pull off right after it cured for the proper amount of time. I was fairly disappointed. Though a lot of others on this forum, haven't had any problems with it yet. Are you painting all of your trim or just some of it? Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 7, 2013 Author Report Share Posted February 7, 2013 I think I want to black out the chrome on the grill and possibly play with the wheels a bit at the moment. So the Krylon is a permanent solution, yes? Quote Link to comment Share on other sites More sharing options...
Echo42987 Posted February 7, 2013 Report Share Posted February 7, 2013 So far it seems that way. I'm sure I will have to re-apply over time. The Plasti-Dip in your situation is perfect. Because come due time, you will be able to peel it right off. But I was just letting you know in case you end up purchasing the vehicle. Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted February 7, 2013 Report Share Posted February 7, 2013 . The plasti-dip' date=' I was able to pull off right after it cured for the proper amount of time. I was fairly disappointed. [/quote'] Thats the point of Plasti-Dip.... Ive ran Plasti-Dip on a crappy set of rims for over 2 years with no issues, with no touch ups. Then before I sold the car, I just peeled it back off, good as new. Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 7, 2013 Author Report Share Posted February 7, 2013 For those of you that use Plasti Dip, do you use anything like the "pre cleaner" dipyourcar.com sells? EDIT: yay for 10 posts and no more moderation Quote Link to comment Share on other sites More sharing options...
Echo42987 Posted February 7, 2013 Report Share Posted February 7, 2013 Thats the point of Plasti-Dip.... Ive ran Plasti-Dip on a crappy set of rims for over 2 years with no issues, with no touch ups. Then before I sold the car, I just peeled it back off, good as new. Weird. I couldn't get mine to adhere at all and same with a lot of other people I spoke with. I knew that was the point of it. But didn't understand how people would ever get it to last more than 1/2 a year. Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted February 7, 2013 Report Share Posted February 7, 2013 Ive always just used a degreaser or normal cleaning agent. If its a small item, I have a bottle of alcohol that I just put on a paper towel and do my final wipe down. Quote Link to comment Share on other sites More sharing options...
EcoBoostSHO Posted February 7, 2013 Report Share Posted February 7, 2013 Same here...I usually just make sure all of the wax is off the area I want to PlastiDip. I did my grille and it is holding up pretty well. There are a couple of dents from rocks but I'd rather have that in the PlastiDip then plastic! Ive always just used a degreaser or normal cleaning agent. If its a small item' date=' I have a bottle of alcohol that I just put on a paper towel and do my final wipe down.[/quote'] Quote Link to comment Share on other sites More sharing options...
Kolk1 Posted February 7, 2013 Report Share Posted February 7, 2013 I just plasti-dipped part of my front grill about a week ago or so. Besided a pressure washer I used the other day to get some salt off the car. I cant really say how its holding up the grill, but it held up to the pressure washer just fine. Quote Link to comment Share on other sites More sharing options...
Jojomofo21 Posted February 7, 2013 Report Share Posted February 7, 2013 I used dawn dish soap to prep the surface and put 4-5 good coats on with drying in between. That was last spring. All my plasti dip is still holding up fine. And I platidipped everything. [ATTACH]1694[/ATTACH] [ATTACH]1695[/ATTACH] Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 7, 2013 Author Report Share Posted February 7, 2013 Thanks for the info Quote Link to comment Share on other sites More sharing options...
steve142857 Posted February 7, 2013 Report Share Posted February 7, 2013 I noticed when I went to pick up my car at Ford bodyshop that the plastidip on front grill had peeled off in the center about a square inch... I was Recommended to use vinyl wash primer under and then plastidip for better grip over chrome, esp. On front grills which are very exposed to rock chips etc. Quote Link to comment Share on other sites More sharing options...
dmharvey79 Posted February 7, 2013 Report Share Posted February 7, 2013 I plasti-dipped the chrome wheels (pitted from road salt) on my Jeep and it is holding up great after about six months, and some mild wheeling. I washed the wheels, wiped them down with acetone, and used two cans to spray them. Not sure I'd want to go that route with my SHO though, if I decide to black out the chrome I'll have it painted by a shop. The nice thing about plasti-dip is it is easy to remove if it doesn't work out and it shouldn't damage whatever you're covering. Quote Link to comment Share on other sites More sharing options...
tss Posted February 8, 2013 Report Share Posted February 8, 2013 I clean with simple green b4 plastidipping. Never had to touch up my rims after 2 tough MI winters. Quote Link to comment Share on other sites More sharing options...
Echo42987 Posted February 8, 2013 Report Share Posted February 8, 2013 This is great to hear after having no luck with it. I would say it's a safe bet then. When I did it I used alcohol and even scuffed up the chrome a bit. But still had no luck. Glad to see there are plenty of positive reports. I just plasti-dipped part of my front grill about a week ago or so. Besided a pressure washer I used the other day to get some salt off the car. I cant really say how its holding up the grill, but it held up to the pressure washer just fine. I used dawn dish soap to prep the surface and put 4-5 good coats on with drying in between. That was last spring. All my plasti dip is still holding up fine. And I platidipped everything. [ATTACH]1694[/ATTACH] [ATTACH]1695[/ATTACH] I clean with simple green b4 plastidipping. Never had to touch up my rims after 2 tough MI winters. Quote Link to comment Share on other sites More sharing options...
83racecrew Posted February 13, 2013 Author Report Share Posted February 13, 2013 Ok, so looks like plasti-dip will wait (darn weather). LED replacements have been ordered for all the external lights (except the puddle). Quote Link to comment Share on other sites More sharing options...
markssho Posted February 16, 2013 Report Share Posted February 16, 2013 Looks great guys! Quote Link to comment Share on other sites More sharing options...
